| Okay. How do you inspect when a wheel bearing, outer tie rod, and control arm is going out? I look around and I see wiggling the wheels different directions and stuff, but everywhere I see tells me something different. How exactly do I check that the wheel bearing is bad. How exactly do I check that the outer tie rod is bad. How exactly do I check that the control arm is bad. Also, if my control arm metal piece is not cracked or broken, I should be able to just replace the bushing yes? Thanks a lot for the help. Jon
